The max blower position does not blow at all, but the other positions blow just a little (heat and a/c).
The heater seems to take a bit to get going. Once it is hot, it seems to do okay.
Questions:
What steps do I take in a logical order to fix this? Resistor, blower motor, thermostat, heater core?
This is a loaner van from a family friend. Should I do anything to it? They want to sell it and I am interested in it, but I don’t want to start fixing stuff if I am not going to own the thing - unless it is an easy repair under $100.
Not sure about the radiator questions. Coolant level is perfect and it looks good - no rust or discoloration noted in the fluid.
Rebuilt transmission that has some up shift issues when you are at higher speeds and need more power quickly. It did a delayed down shift today but no hard jerking.
No, the air flow is not coming out where I want it to. It kind of seeps out everywhere even when you can hear the variation in each of the blower speeds.
No check engine light on.
Rust is non-existent. It has stayed in New Mexico all its life in the desert areas.
So should I replace the blower motor as a starting point? That is only $40 and I think I can do it myself.
If, as you say, you can hear the variation in each of the blower speeds, it can’t be the blower motor. If it seeps out everywhere then the doors in the ducts aren’t opening properly.
As @db4690 said the highest speed is controlled by the relay on the resistor module. Either this relay has failed or the speed switch is not making contact for the highest speed. You also can’t rule out a wiring or connector problem.
Those sound easy enough. Thanks for the advice folks. I think I am going to just give the van back to its owner and look for something else once we get moved.
