A tip for 2000 Corolla owners, I hope it helps someone. At 200,000 miles you could see on occasion steam billowing from under the hood when stopped and always smell antifreeze yet only added a little water once. Couldn’t tell where it was coming from, it stopped when the engine was off. It worried me to death for almost a year as it got worse so I changed the water pump and it’s still steaming. Now worried about the head gasket but the alternator had a slight bearing whine so I bit the financial bullet and replaced it because it mounts up solidly against the water pump and it stopped steaming 30,000 miles ago. I got off easy that time, I could have spent a lot of money on that one.
Related topics
| '09 Toyota Corolla 75,000 miles | 14 | 3823 | January 24, 2014 | |
| 2000 Toyota Corolla - Trans fluid leak | 2 | 1000 | July 21, 2020 | |
| 2000 hyundia heat | 0 | 269 | December 7, 2008 | |
| What is this leak behind the exhaust manifold? | 32 | 9025 | January 30, 2017 | |
| 2000 Camry - Steam from Radiator, noise from exhaust | 10 | 2452 | February 23, 2014 |
