I have a 2000 Chrysler Concorde LXi. It is having an intermittent climate control display problem. It will be lit for weeks/months, and then without warning, the display will disappear. In the past, a smack of the display would cause it to reappear or a press on the lower left of the panel below the display would make the display reappear. Seems as though there is a loose connection. Fuse ok. Does anyone know how to remove the climate control bezel or get to the connections?
Thanks in advance for any help!
