I RECENTLY HAD MY TRANSMISSION TOTALITY REBUILT AND NOW THERE IS A VIBRATION AT ABOUT 2000RPM. MECHANIC SAYS IT IS IN THE ENGINE, but it did not do it until TRANSrMISSION was worked on. What may be the problem? Thanks
The driveshaft may have been re-installed out of phase, may have had a balancing weight knocked off or the U-joints are failing. Have all that checked. If it is a transmission problem, you should have a warranty on the repair.
Why are you screaming at us.
WE DIDN’T DO THE WORK!!!
Yosemite
