A family member took her 2000 Buick Century into a repair facility to get an alignment. They changed a inner tie rod on the driver side. The technician forgot to slide what looks like a plastic retainer back into place and the rack n pinion is now leaking fluid from that side. The steering is now grabbing or jerking to the left. What has happen? Can this problem be fixed or does the rack n pinion need to be replaced? Thanks for any advice you may have.
Related topics
| Rack and pinion installation puzzle | 13 | 2845 | May 30, 2023 | |
| Did mechanic break my rack and pinion? | 32 | 35876 | June 26, 2014 | |
| '99 Taurus, rack and pinion | 21 | 4608 | December 18, 2013 | |
| Rack and Pinion Leaking At Inner Tie Rod Joint | 5 | 5403 | September 19, 2019 | |
| 04 Buick Century Steering. (stiff) | 8 | 2141 | September 2, 2015 |
