My 2000 Acura Integra GSR (w/190,500 miles) sometimes will not go into second gear when I downshift while driving. It also stops rolling in reverse when I depress the clutch. I can hear pronounced gear noise while driving. When the car is off, it cycles through all gears without a problem. I replaced the clutch in 2005, for the first time. I’m hoping it only needa a gear oil change. My research has indicated that the problem could be a throwout bearing. Can You help?
Related topics
| New clutch-stick shift popping out of gear | 6 | 8018 | September 11, 2009 | |
| Faulty clutch replacement? | 1 | 563 | August 25, 2009 | |
| Automatic Downshifting | 6 | 843 | June 21, 2008 | |
| Mystery problem with clutch. HELP! | 12 | 7597 | January 26, 2011 | |
| Clicking noise when accelerate | 0 | 264 | September 6, 2008 |
