some times it is hard to start cold or hot. it is like a rubber band you have to wind up. after it is running it seems to run fine. have took it to dealer and they said that it needed a tune up and i did that. and that has not worked eather. please help?
Try a can of Sea Foam cleaner in the fuel tank. Then, change the fuel filter.
