- Heater/AC fan only works on high. How can I get the switch out to see if a connection has fallen off or is broken?
- The radio works intermittently. How can I get it out to see if there is a broken or loose power connection?
Replace the blower resistor, it is inexpensive.
The radio bezel should pop off using a plastic trim tool. Plan on replacing the radio, you may not be able to repair it.
Thank you. Very helpful.
Thank you for the tip. Do you know where the blower resistor is located?
Happy New Year.
James
If this is a convertible; remove the right side under dash cover, the one below the glove box. You will find the blower resistor next to the blower motor.
