Recently I went out to start my car and the engine kept turning but would not start. The car had driven fine the day before. The temps at the time were hovering around 20degrees. I had a friend to look at it thinking it might be a battery problem. But we discovered it wasn’t the battery. My friend also determined that there is no spark getting to the spark plugs but there is fuel at the fuel rail.
what gives…
Then the fault lies within the ignition system. It will need testing at different locations to locate the fault.
This may need to be hooked up to an oscilloscope.
