1998 Toyota 4Runner - Clutch every 4 months
3 clutches in 1 year.
Have owned this car since new so I know how to drive it.
now I am worried it may be the transmission
What do you find when you go to replace the clutch?
If this has a hydraulic clutch, have you ever replaced the master, slave and especially the flex hose on the clutch? If the flex hose is original, it may be acting as a check valve holding pressure on the slave. The net effect is exactly like the driver resting his foot on the clutch.
