1998 Honda Civic 1.6L Ignition Timing Not Aligning
Do any of you know what’s the percentage that the throttle body should be opend at ? When it’s closed
The absolute throttle position % ?
I think I found the problem on my car, with idling.
When I try to calibrate my tps, the voltage I get when the throttle body is closed is .52 and open 4.62
Is that bad ?
Supposedly the cara tps should be at .50 closed and 4.50 open but I can seem to get to there.
If I put it there the absolute throttle position is at 8.6, when it should be at 9.8 or 10.2 that’s what I’m wondering too
i think you should send it out to be properly diagnosed, or if you insist…go spend the $25 for a Hayes or Chilton manual that covers this car.
Yosemite
