Hi there, about 2 weeks ago my wife had a minor fender bender and cracked the lense on the headlight/turn signal. Since then the turn signals have not worked. Checked the fuses, all look good. Could you please throw a little light on the subject .Regards Gary
It may have damaged the lamp breaking the filament, or maybe damaged wiring or something came loose.
You should be able to buy a new after market head light assembly for between $50.00 and $100.00 dollars. Replacing shouldn’t be that hard or expensive if the inner mounting points are not all bent up.
