1998 Honda Accord LX Heat Issue
Two years ago, I purchased a 1998 Honda Accord LX from a local dealer. I’ve had very few issues with it. However, shortly after I moved from Michigan to Florida, I began to notice a strange issue with my car. While the car is running and the engine is idling, I lose AC inside the car and the engine heat slowly begins to build. The AC isn’t shutting off, but instead blowing out warm air. The engine heat builds at a concerning enough rate, moving from a normal level to almost maxxing out the gauge in the span of 20-30 minutes. This issue seems to auto-correct itself while the car is in motion, with the AC putting out nice, cool air and the engine heat staying at a normal level.
The car currently has about 269,000 Miles on it. I have been told the problem is likely a faulty thermostat, but I’d like a second opinion. What might be wrong with my car?
Check to see if the radiator cooling fan is coming on when the AC is turned on.
You have two fans and both should be running when the AC is on. If either doesn’t, it needs to be replaced.
