1998 Buick Regal backup light switch
The backup lights don’t work and a simple test shows the wires have no power. The bulbs test good. I also checked all the fuses and they are good. Where is the switch located? Also, I searched AutoZone online for the part and get no results. Any assistance would be greatly appreciated. Thanks… Mark
The reverse light switch is part of the park/neutral safety switch or transmission range switch. Look that part up.
I saw that and didn’t look into it. Do you know where it is located? Thanks… Mark
Look at the top of the transaxle, and where you see the shift linkage, look below that and you’ll find the switch.
I appreciate that. Thanks… Mark
