1997 Honda Odyssey ignition
If it’s an aftermarket alarm I would get it removed. Have you tried putting the car in neutral and trying to start it. If it starts then the neutral safety switch is the fault. The alarm system definitely could be the problem. If it is aftermarket I would have it removed. Make sure all battery connections are clean and tight. I would have the battery load tested at Autozone or Advance for free.
