I have a 97 Dodge B1500 3.9 V6. It won’t start. I’ve changed; the plugs, Coil, Cam Sensor (bottom of D-Cap), Ignition Switch assembly , Battery, Fuel Pump, and cleaned the IAC.
I have 60 psi Fuel at the rail, Good spark, 130 psi Compression across the board, and no ideas left. HELP
If it won’t start with fuel in the intake then you need to verify there’s a healthy spark present at the plugs.
How many miles on this thing? That 130 PSI of compression could be a cause for concern as it is too low. Ideally you want up in the 180s so 130 points to a looming problem.
No Check Engine light. I did pull a P0320 code with the ignition switch on. I am getting spark so the crank sensor must be working. There is 166,532 miles on it.
If worse comes to worse, you might consider pulling the plugs, giving each cylinder about a tablespoon of motor oil, reinstalling the plugs, and attempting a start then.
If the engine fires up then the problem could be due to the lowered compression. In theory a 130 should run but that’s not always a given.
I’m reminded of the Dodge a dealer I worked for had on the lot that would not even cough one morning. Compression on 8 cylinders varied from about 90 to 125. The vehicle was given the motor oil treatment and it fired right up with compression returning to the normal 175-180 and never a problem again.
The lot porter had fed the vehicle too much ether one very cold morning while trying to start it and the starting fluid had washed the cylinder walls down which in turn lowered the compression.
Sounds like the timing chain jumped a few teeth. The 3.9L timing chains are known to stretch, there is a guide/tensioner available so the replacement chain won’t slap the timing chain cover as it wears.
Align the crank to TDC on the #1 compression stroke and check if the distributor rotor is aligned with the terminal for cylinder #1. If not the timing chain may have slipped.
Ok Sorry for the delay. Just checked the TDC and its right on the money. I also added oil to the plug holes. It started for about 15 seconds and died. Ran really rough though.
no this would be a box under hood somewhere, may be called ignition module or something. just has a plug going into it. they can cause all kinds of weird problems then eventually you can t even sart up. can be hard to diagnose and they will sometimes test ok at the parts store even if they are bad. make sure they test it a few times. if you find one they can be removed easily and many parts stores can test them
Good spark or intermittant spark? Have you replaced the crankshaft position sensor? There are still a number of possibilities but the CKP sensor is the simplest.
