1996 Toyota
Even though this is an older model, should I re-floormat my 1996 Toyota Camry? Is this the same as re-floormatting a hard disk?
I own a 2007 Toyota and it is not even on the recall list. Your Camry is probably not covered, but check with your dealer.
Hard disks would certainly make durable floor covering, but no doubt a bit slippery!
You must be referring to flash re-programing.
This must be a joke. Ha. Ha.
“Never mind.” Emily Litella
Yup. Just insert your floormat into the disc drive and press the button.
