1996 Toyota Corolla smells like it’s flooded
Car will not start it smells like it is flooded when I try to start it I’ve tried taking the plugs out and wire brush them but still nothing
Just a wild guess but I’d check for a fuel leak. There may not be enough fuel getting to the throttle body. Is this a constant problem or does it just not start under certain conditions like when the engine is hot?
Locate the fuel pressure regulator on the fuel rail.
Remove the vacuum hose from the regulator.
If gas leaks out of this connection, the diaphragm in the regulator has ruptured and gas is being sucked into the engine as you try to start it.
