1996 Buick Park Avenue Start Problem
Occasionally, when I attempt to start this 3.8L engine, nothing happens - - no clicks - - nothing. In this mode, when I make a direct connection to the starter, the engine starts but stalls after 5 about seconds. It will eventually start with the direct connection. Suggestions welcome.
If the vehicle has the side mount battery terminals, remove the positive cable from the battery and inspect it for corrosion.
If any is found, peel back the rubber cover for the terminal and see how bad it is. Sometimes the terminal is so badly corroded the cable must be replaced.
Thanks, cables have been cleaned. Didn’t look as bad as your Picture but there was some corrosion there. I have been unable to reproduce the problem so all I can do is cross fingers.
That’s a very reliable engine, I git 520k on mine. But if it starts and stumbles or cranks and doesn’t start, suspect fuel pump and look for a replacement car.
Do you generally replace the car when the fuel pump fails? :grinning:
Yeah, it’s available, not hard to find.
I would on a 30 year old car unless it had collectible or sentimental value.
Not a mechanic but thinking get it back to normal. Shift interlock switch first stab at the cat.
I had that engine in my ‘99 Monte Carlo. My model year time frame had upper intake manifold issues with high mileage. Rockauto had a Dorman replacement that addressed the issues and I installed it.
The GM cable ends. I had a starting and charging issue and found corrosion in those GM side mounted ends. You can take the plastic covers off the metal end and use a wire brush. Clean them up good, put some dielectric grease on them. My cables then lasted until I sold it years later.
I think GM has given up on those side terminals, My 2017 Chevy Volt has normal top terminals.
Edit: My 99 Monte fuel pump did not have access from a hatch under the rear seat to the tank access. You had to drop the tank to work on the fuel pump/level sender. I think most newer cars have a “door” under the rear seat to access the tank hatch.
Thanks - - cleaning the cables, which I have done at Tester’s advice above, is cheap and easy - - and I have my fingers crossed it will work.
A bad fuel pump and or intake manifold on the OP’s vehicle will not keep it from cranking, only no start and or stumble…
If it persist after cleaning the cables, then the next step will be to move the shifter to neutral to see if it starts and or maybe even hold the key in start position and move the shifter through all gears to see if any start it, if so then replace the neutral safety switch (NSW).. Or make shift linkage adjustment as needed…
If it is not the NSW, then move to the starter and check for voltage at the signal wire on the starter (only) while in the start position, or you could just smack the stater to see if it helps 1st, if no signal then trace back until problem found, possible failing ignition switch…
That simply could be from not priming the fuel pump before starting it, maybe loosing prime, I would almost be willing to bet if you had someone in the car that turned the key to run right before you jumped the starter, it would start right up…
I agree the fuel pump or intake problem cannot cause this issue. I will try your suggestions at first failure - - hopefully that won’t happen. Your input is appreciated.
Neutral safety switch? Have you tried starting in neutral?
Ignition lock? Have you checked it for proper operations (voltages when turned to start and to run)?
Yes, I have tried to start it in every gear when it fails. I have not checked any voltages - - yet. Historically, it has failed on the first attempt about once a month but it was always followed by an immediate successful start - - so I just tolerated it as a minor inconvenience. But I was suspecious of that ignition switch. Thanks for your suggestions, I appreciate it.
Yeah had that too. Mine just needed to be adjusted up a little on the steering column.
I bring up my 99 Monte because underneath the body it is pretty much the same as the OP’s 96 Buick.
The last couple years I had my Monte it developed the “stumbling” start. Doing a little reading online I found out some older cars develop “leaky” fuel injectors. So the residual pressure fades away. So my habit became: Turn the key to run. Pump runs for 2 or 3 seconds (I could hear it). Then to crank and my car would start right up.
Also clean the ground connections of the negative terminal and fender.
Im having problems with a 94 Buick Park avenue. I am new here and do not know how to start my own thread. The security light is on and stays solid. I originally thought this was causing it to stall, but I found that the ground bus bar on the driver side was corroded. I repaired this and it fixed the stalling issue. It is currently also having climate control issues and it has the automatic climate control. It currently says it is 110 outside but the whole thing will freeze. When it does this the passenger side climate control will also freeze. The blower will only work until it freezes and then it will stop. Once you restart it the climate control will go blank. I know this is a long post, but these issues have me confused as to what to try next and any help would be appreciated.
You’re probably looking at a faulty climate control module.
