1996 2.2L 2wd Chevy S-10 - How to remove rear part of the two part driveshaft?
I’m currently trying to remove the rear driveshaft of my truck. However, the front part of the rear driveshaft will not come out and it doesn’t look like anything is holding it. Anyone know if there is something thats keeping it from coming out?
Just slides right out. Pull harder.
If it is a two piece dribeshaft, I assume it has a carrier bearing in the center that is bolted to something. Remove those bolts, remove the two bolts holding the driveshaft to the differential. It should pull right out.
