1995 honda electric windows works sometimes
1995 civic power windows work sometimes
driver side used to work, not now! back ones sometimes checked all fuses good replaced window control gang switch made no difference!what could it be all? 4 window motors cant stop working at once?help
It would be helpful if you would explain the problem in a bit more detail. (Punctuation helps, too, this isn’t Twitter.) For example, if at the time when one window would not work, would the other windows work properly, or did they all fail together?
Start by cleaning the window tracks and lubricating them with silicone spray. You’ll probably need to remove the door panels to reach the tracks inside the door.
Sometimes dirty, dried-out tracks prevent the windows from working properly.
