1995 Ford E150 - Misfire and oil leak
Miss buying oil leaking on the ground losing power
You miss buying oil? Because it was leaking on the ground and you were losing power.
I’d be happy not to be buying oil plus getting the power back
Are you going to tell us how you fixed the leak?
Car Talk’s current weekly column is about engines that lose oil. Click ā€œCar Talkā€ upper-left this page
And ruin the suspense?
Your post is pretty unintelligible. Please try again to explain the problem(s) you want help with.
