1993 Saturn SL - Crank Sensor?
the saturn sl model was shutting down at times,then would start later,then it completly quit,I was told it could be the crank position sensor,behind the starter as it explained on vidios ,any1 familure with this crank sensor problem?[1993 saturn sl2,twin cam motor]
did you get a check engine light with a code for the crank sensor?
many things could cause your problem.
I can’t tell you how many crank sensors I have replaced over the years on Saturns.
Some owners of these cars would have to replace their crank sensors yearly.
Some got so use to these failing that as soon as they were experience the same problems and call and just say, It’s time to replace the crank sensor again!".
And since your vehicle is an OBDI vehicle, there are no codes for a failed crank sensor.
11 Transaxle Codes present
12 Diagnostic System Check
13 Oxygen sensor, circuit open or not ready
14 Engine coolant temp. circuit. Temp. out of range high
15 Engine coolant temp. circuit. Temp. out of range low
17 PCM fault, pullup resistor
19 1991Perf. (LLO) 1992-1994 vehicles. 6X signal fault
21 Throttle position circuit out of range high
22 Throttle position circuit out of range low
23 Inlet air temp. (IAT) out of range low
24 Vehicle speed sensor (VSS) circuit, no signal
25 Inlet air temp. (IAT) out of range high
26 Quad Driver output fault
32 EGR system fault
33 MAP sensor circuit, out of range high
34 MAP sensor circuit, out of range low
35 Idle air control rpm out of range
41 Ignition control circuit open or shorted
41 A EST circuit open
41 B EST circuit shorted
42 EST bypass, open or shorted
42 A Bypass circuit grounded
42 B Bypass circuit open
42 C Bypass circuit shorted
43 ESC (knock sensor) circuit open or shorted
44 Oxygen sensor indicates system lean
45 Oxygen sensor indicates system rich
46 Power steering pressure switch circuit, open
49 Idle rpm out of limit high (vacuum leak)
51 PCM memory error
55 A/D convertor error in PCM
81 ABS message fault (1993+ vehicles with TCS)
82 PCM internal communication fault
