My Geo Metro will not start and run if the temp. is below 30 degrees. It will start and run for about 20 seconds, then die like it ran out of fuel. I can have the throttle open most if not all the way and it still dies. I have replaced the coolant temp. sensor and the throttle position sensor. I have tested the air temp. sensor and it tested good. If the outside temp. is above 30, it starts and runs, but not too good until it warms up good.
Related topics
| Geo Metro refuses to start when warm | 5 | 4862 | January 10, 2008 | |
| Hard Starting | 4 | 578 | January 12, 2010 | |
| 1997 Geo Metro Won't Start Once It Warms Up | 8 | 5362 | November 15, 2015 | |
| 97 Geo Metro won't start in morning | 0 | 317 | September 18, 2008 | |
| TPS vs Throttle Stop? | 19 | 4784 | May 13, 2009 |
