1981 Chevrolet 2500 - Misfires on Uphill Climb
Misfires on long uphill climb
Too bad. More info needed, much, much more.
If spark plugs, spark plug wires or any ignition parts need replacing, the symptoms will show up first when going uphill because that is when you are putting the most load on them.
A worn timing chain can cause that.
