climate control blower switch
I’m guessing either faulty switch, or faulty blower resistor. Is it only the low speed that’s not working? If so, blower resistor is probably the problem.
Low speeds 1 and 2 are fine, but it loses detent and it’s nigh impossible to get speeds 3 and 4 to lock.
Seems more like a faulty switch then. The best solution? Ask your shop to verify the switch is bad, then replace the switch.
Note: Suggest to edit your post to remove the personal data. Click pencil icon.
You should delete your personnel info. this is an open forum, and you never know who will stop by.
@cdaquila A little edit work for you Carolyn. Stephen forgot to post his bank account numbers.
So just have the switch replaced.
