1 second gain
not manually, I let automatic box to do by itself
what were your 0-100kmh gains
I didn’t tested 0-100 as the most common speed intervals are 50-100 and 80-120 kmh on the roads I drive, so I was interested practically what is the gain on those
Still don’t understand why you are afraid to give us the details about your car unless what you are talking about is SNAKE OIL one size fits all.
I can gain a second or more without the box. first run shift at 3500 rmp, the rest of the runs shift at 6500 rpms.
most times are tested at 0-60 mph
It isn’t an additive, there are many performance enhancement products available, being a truck driver I’m sure you have heard of Bully Dog and Banks.
might be, but I’m not looking for that kind of racing approach :slight_smile: I’m expected the car to do by itself using automatic box…and it seems that it is doing…based on tests done by now
how are you timing the difference? does the box tell you or a stop watch?
Yes I realize it is not an additive bit I still think it is funny whenever the OP is asked for details he sidesteps the question every time.
OP will not give vehicle info or where he lives that this 1 second is so vital to his well being on the road passing other vehicles.
Without knowing about the vehicle you guys can’t challenge his claim, this is torture. On the other hand, if you are not interested in power modifications why does it matter?
I think the problem is why he wont be upfront on what his vehicle is. the 30mph-60 sec. gain seems like a lot. the new C8 corvette has a 0-60 time of 2.9 sec. I think if chevy put this box in the vette with no problems and gained a sec. they would, just for bragging rights. but thats just my opinion. which doesnt mean much. lol
Depending on which vehicle this DCT is in, I’d be loathe to do any real performance improvements without thoroughly researching the ability of the transmission to handle it. The DCT in my wife’s Veloster is fine, and has lasted a lot longer than I predicted it would when she got it, but I’m pretty sure it wouldn’t like handling much more power coming in from the engine.
So it’s a good thing that this magic box probably isn’t doing bupkus. :wink:
Depends a ton on the vehicle. Mainly, it depends on if the vehicle is turbocharged or not. Put a good tuner on a NA engine, your shift points are better, throttle response is improved, timing is raised a little (you have to use higher octane fuel, generally), and you get a little hp. Put a tune on a turbocharged engine and raise the boost, you’ve got some real gains. I’ve driven an old Dodge with a Cummins diesel tuned vs stock back to back just for fun. It’s a world of difference there. Of course you void your warranty, increase your chances for engine damage, etc, etc. You have to pay to play, as they say.
I’ve even seen the common as dirt foxbody gt’s (nice original ones with low miles) selling for $25-30k. Which would be reasonable if (like Shadowfax stated) you couldn’t buy something newer, nicer, and faster for less or the same…with a warranty. I bet they will continue to go up in price as they become rarer and as the guys that wanted them when they were in high school get older.
My dad bought this a couple of months ago for low $30’s. I think it’s one of the best looking Challengers I’ve seen.
thats why there was so many questions on OPs car. he would not say for some reason and put some doubt for a few of us.
Yeah, I get it. He might be schilling something, I dunno. Don’t care much. If he’s not, then accusing him is kinda rude. If he is…well y’all got him, Sheriff.
The key word here is “good.”
I can understand how this thing is supposed to work, and I suspect it’s possible that it even does work (after all normal boost control devices work). It supposedly intercepts sensor-generated values for things like RPM, boost, etc, and then lies to the ECU about what those values are.
So for instance if the ecu-controlled wastegate actuates at 20 pounds and your turbo is putting out 19 pounds of boost, this thing will tell the ecu that the turbo’s putting out 15 pounds of boost, so the ecu won’t dump boost until the real boost is more like 25. (Imaginary numbers).
So, yeah, overboosting the turbo might well get you some pretty good gains, but at what cost? The box isn’t gonna build the engine’s internals to take more boost, so you have to hope the factory was generous in overbuilding the engine beyond what they intended for it to handle and more importantly beyond what this box tricks the computer into allowing.
I also automatically dislike DTE’s marketing section where they say that if your car is under warranty you can pay them to remove the device before service, then re-install it after service. Any time a business says “we will help you lie,” you should add “and we will also lie to you” to the end of that.
no, I wasnt accusing him. just dont understand what the secret is about his car. and trying to understand the gain better. like you said is it turbocharged or not.
