It wants start but it only starts like once or twice a day is very heating like crazy it’s full of coolant need help
So it starts without problems 1-2 times per day? But other times it won’t start at all? When it won’t start, does it crank ok, but won’t catch and run? Or is this no-crank problem? How many times does it not start compared to the times it does start?
If it is “Overheating like crazy” as I am deciphering from your post…I think you have a breach in the heat gasket which is fouling the plugs. You are just lucky enough that it does start at times and then it overheats.
Yosemite
