When I start the truck in cold weather, the transmission doesn’t want to shift out of 1st gear. Some time it take driving it a 1/8 of a mile before it shifts.
Any ideas what is wrong / need replaced ? I was told to shift it thru all the gears before I move it to help warm up the transmission fluid ? I’m thinking some sensor needs replace ???
I have a 2005 Dakota 4X4 with the 4.7 V8 and 5 speed automatic. I have the same issue intermittently when the engine is cold (not only in cold weather but also if the truck hasn’t been run since the previous day).
I asked the dealer about this and I was told that this was done by design and controlled by the computer. It is done (so I was told) to help the transmission fluid warm up more quickly.
Check with your dealer the next time you have your truck serviced.
