Join the Car Talk Community!
Discussion Rules
Sign In Register
Audio Not Working
Hey All,
So in my car is an aftermarket head unit (installed by previous owner). It turns on and everything, but with all radio frequencies and CDs, no sound comes out at all. This is in a 2004 Civic LX coupe.
I'm pretty handy, so if it is a self-repair/diagnosis, I'd be very happy.
  • Sounds like either you have no speakers, or bad wiring to the speakers, or a blown amp.
    If the continuity on the speakers and wires is good, replace the head unit.
  • Maybe take a know working unit out there and plug it into the speakers, see if any sound comes out. Then you'll know if it is the speakers or wiring to them, or the unit itself. One more thing to consider: Do you have the owners manual for the unit? If so, read it. You may have accidentally hit a button which turned the audio off.
  • Alright so I called an audio shop, they said that the previous owner might've had an amp installed and now that it's gone (I couldn't find one), the audio is out too.
    Quick question, I should be able to find wires to where the amp should've been right? If so, what are some common areas to install an amp?
  • Ok, I'm getting the whole picture now. So sound has never come out of this unit since you bought the car? You might be able to follow the audio wires to where the amp was or is installed. It depends on how they ran the wires though. Might be tough to do. Aftermarket amps -- especially the high powered ones -- are often installed in the trunk area. Mabye take everything out of the truck, even look in the spare tire area, maybe you'll find it, or see where some holes have been drilled.
  • Ok, thanks George. I'll try and post an update in the AM.
  • edited December 2012
    Look on the battery for large red wire connected to the positive battery terminal. If there is one there's a seperate amp and the fuse on that wire may have blown. If there is no large red wire, then there's no seperate amp for the sound system and the amp in the head unit has probably failed.
  • in a Honda look under the front seats or it can be in the trunk.
    ''aftermarket'' radio ?
    All bets are off now concerning anything Honda.
    Look for an amplifier , they usually have their own internal fuse you need to check.
    The radio head may also have its own fuse in the rear of the unit.
    Also check for a separate circuit that may have been tapped for either the head or an amp and see if that has a fuse in need of tlc.
    Here's another thing about aftermarket sound and second owners ;
    VERY , VERY often the first owner will REMOVE their precious high dollar amplifiers and maybe even their super-duper speakers too, and leave the next owner holding the bag.
    -----check the entire system for signs of MISSING components. ( usually in the trunk )-------
    If components have been removed you can opt to wire the head direct to speakers in the simple set up the head could have without the hotshot system.
    Next step , take it to a sound system specialty shop ( not a Honda dealer ).
  • Looks like an amp has been removed, if I'm not mistaken. I'll search for where it used to be connected.
    3264 x 1952 - 3M
  • Herp Derp... I don't even have speakers at all. I guess they did decide to take out all their expensive equipment. At least all the wiring is in place.
    Can this be a do it yourself job?
