Join the Car Talk Community!
Discussion Rules
Sign In Register
Acura TL Service Codes
I have a 2007 Acura TL and can't find the service codes on line. Does anyone know where I can find the list of service codes for it? Specifically, I am getting the code B15, getting that one would be a good start.
Comments
  • edited July 2011
    Service B:
    Replace engine oil and oil filter
    Inspect front and rear brakes
    Check parking brake adjustment
    Inspect tie rod ends, steering gear box, and boots
    Inspect suspension components
    Inspect driveshaft boots
    Inspect brake hoses and line (including ABS)
    Inspect all fluid levels and condition of fluids
    Inspect exhaust system
    Inspect fuel lines and connections
    Service 1:
    Rotate tires
    Service 5:
    Replace engine coolant.
    You can find more by inputting your vehicle at owners.acura.com
  • thanks for the info, did you find that online? Or, is that in a manual?
    Looks like the letters and numbers mean something by themselves, the B the one and the 5?
  • Yep. You're getting 3 service codes, not 1.
    That list (and all the other code lists) were found at owners.acura.com
