We discovered that our 99 mercury Mountaineer had bad rotors.
last night I hooked up a trailer and was going to help a friend move a couch when I heard a loud grinding sound.
I turned around and determined it was comming from the wheel. I purchased a new set of pads and started to change the pads. In the process I found a broken sway bar connector. I changed this as well.
It still felt bad and there was a sound when I braked. I took it to pep boys for a free brake inspection. They pointed out that the rotors needed to be replaced.
I did not let them do it because I can not affor that right now. The car is a secondary not a daily driver.
My wife says we shouldn't drive it at all. I say we can still drive it and expect I will have to replace the brake pads sooner than normal and replace the rotors when we can, later.
My wife insists we will do more damage if we drive it as it is. I say what's the difference we need to replace the rotors anyway and I'm not worried about $20 brake pads I can replace myself.
0 •
Comments
If this isn't an everyday vehicle you'll be good for now. But eventually the rotors will warp from poor friction material contact. When this happens replace both the brake pads and rotors.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeSo other than that, the only things effected are the brake pads and rotors.
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe new pads will wear quicker on used rotors since the rotors are "grooved". As long as you stop reasonably quickly you should be ok. If you have extemely long stopping distances and poor braking performance then you are due for new rotors.
After about 200 miles your new pads and old rotors should be mated up as best as they ever will. If you have decent braking performance at that point you should be ok until you need another new set of pads.
Thin rotors can warp easily. They also don't transfer heat as well and that degrades stopping heavy loads, on hills, and in emergency panic stops. As it is, you car is less safe than it could be. It is hard to tell if you are unsafe to the point of dangerous.
- Spam
- Abuse
- Troll
- Abuse
- Troll
