Join the Car Talk Community!
Discussion Rules
Sign In Register
engine oil change for break in period??
When should I do the first oil change on a new 6.0 liter gmc van? It has the computer which tells you when to change oil. Shouild I trust this for the initial oil change? Do you have a suggestion based on engine hours as the van engine is used to run a pto source which is significant.
«1
Comments
  • edited April 2010
    I would change it at 1000 miles or 100 hours, then 5000 miles or 50 hours..But with today's engine building technology, that first oil change is probably optional...
  • edited April 2010
    I agree. I like the idea of changing any new vehicle's engine oil at about 1K even if the owners manual does not state doing so. Change the filter as well because that's where the grit and metal debris is likely to be.
  • edited April 2010
    thanks- I should have stated I will not be using synthetic oil.
  • edited April 2010
    Leave it alone. More damage is done to engines by botched oil changes than any other cause. Don't do anything early on the van, it has an oil filter. No problem? No repair.
  • edited April 2010
    The question you should REALLY be asking yourself is "what does my owner's manual say?"
  • edited April 2010
    So I assume you never change your oil?
  • edited April 2010
    Not before it is time. No need to do unnecessary work.
  • edited April 2010
    Some manufacturers have used a special break-in oil, for example with added molybdenum. Honda was one who did this. I don't know if they still do it.
    If your car's initial oil has any special break-in properties, changing it early will defeat the purpose.
  • edited April 2010
    What does your owner's manual say about this? Your owner's manual is the definitive source of information on this issue.
  • edited April 2010
    They say to follow the engine oil life sensor which monitors life of oil. It is hard to get used to technology!!
