3 speed 1980 ford f100. i can shift into first and second fine but when ever i try to shift into 3rd it grinds hard. i just got a new clutch too. any ideas?
Were you able to shift into third gear before the new clutch?
Linkage on the column or floor?
yes i was able to shift before. i brought it into the shop because one morning it wouldnt move. like i couldnt shift into any of the gears. it was like locked up or something. The linkage is under the truck so i guess the floor?
Sounds like a linkage problem, better than a internal trans problem.
Have someone move the shifter while you watch the linkage,look for levers slipping and not moving shafts.
ill check that out and report back thanks.
