Why are my driver side door panel armrest button lights not shutting off? Be 08 Honda accord
Why are the driver side door panel armrest button lights staying on even after I shut off the car. My driver side door seal is broken, so when it rains water leaks on the driver side, door panel. Could this be it?
Yes, water intrusion could be the issue.
Suggest to get that fixed, b/c the OBD II connector is located in the same area. If that gets wet, could cause the car’s CAN-BUS to fail. A problem you definitely don’t want.
