Hello all,
I noticed a white smoke on my 2001 Toyota Camry recently in the morning and since then the white smoke refused to stop. I was actually thinking it’s oil because I recently serviced the car and change the oil with same oil I normally use. Have 119k miles on it. Need help please.
White smoke is more likely to be coolant being burned than oil (oil is usually more blue tinged). Have you checked the oil since you changed it? What’s the coolant level?
You had old dirty oil before? Now you have new oil. And you think that is causing white smoke? Explain your theory.
The coolant level is ok
The valve guide seals are leaking.
