VERY INTERESTING IDEA!
IF you have access to a vehicle that has instant and average trip readouts that can be reset to ZERO, cruise control, and a 3 to 5 mile level course with established start and end points without stop signs/lights in between so that uniform cruise speed can be maintained, then you could run your own experiment with several trials. I recommend a minimum of 3 trials using high, medium, and low accelerations.
Set cruise to the planned cruise speed, reset mpg readouts to zero at the start point, accelerate at maximum and just before you reach “planned cruise speed” activate “RESUME” to engage the cruise control for the remainder of the course, imediately stop and record the data from “trip mpg”. It is probably of greater value (more meaningful) to divide “trip mpg” into one (1) in order to get gallons/mile.
Reset the “trip mpg” and repeat the proceedure using very easy acceleration to “RESUME” cruise speed to the end of the course. Again, stop immediately, record “trip mpg”.
And when convenient, calculate low acceleration “gallons/mile” and compare to the high acceleration results.
IF … you wish … you could do a “trial” at an intermediate acceleration just as a check.
If you have someone with you that can measure your time from 0 to “RESUME” cruise speed then you can plot “gallons/mile” versus “acceleration time” on grid paper to see IF there is a linear (straight line) relationship between “gallons/mile” and “acceleration time”.
I suspect that HIGH, MEDUIM, and LOW points on the graph will actually be a curve instead of a straight line.
The experiment is certainly all doable.
However, keep in mind that these results apply specifically to that specific “test vehicle”, and [b]MAYBE[/b] that model configuration. Other makes/models will probably get different results. But the trends will probably be similar.
IF … someone suceeds in doing the experiment, I hope they will share the results!
It should be interesting …
