Where is the ground for the horn circuit on a 2000 Protege?
Hi there,
The horn on my protege isn’t working, when I hit it I just hear the relay clicking. The relay from my old protege I put in and all I hear is clicking.
Its a “new” protege.
I put 12V on the physical horn, and it beeps.
I am suspecting bad ground.
The shop manual I have doesn’t show the ground locations :neutral_face:
Does anyone know where the wiring loom, near the radiator goes to? Straight to the relay?
If someone could post a nice diagram that would be great.
Thanks,
Have you checked the 15 amp fuse in #13 under the hood?
The wiring diagram only shows one wire to the horn, the power wire. The horn is grounded by the mounting bolt.
I managed to fix the horn, it was the connector to the horn that was damaged ( God knows how it gets damaged)
I cut off old connector, and crimped on a female connector ( not OEM standard ), but it works now.
Thanks and have a great day,
Ryan
