When should I replace the water pump in my 2008 Lincoln MKX?
I’ve never seen a water pump catastrophically fail without warning anyway. I’m sure it happens from time to time. But generally you get a lengthy warning sign of either a coolant leak and / or squeaking bearings.
So I agree, I wouldn’t change it if there isn’t an issue with it, unless it’s getting removed anyway (replacing timing belt, replacing timing cover gasket, or something along those lines).
