I’ve got a 2005 Avalanche (basically, a Silverado) which has suddenly developed a possible illness. Whenever I start the truck and begin moving (forward or reverse), I hear one (and only one) loud squeak that seems to be coming from the general area of the torque converter or drive shaft (but who knows exactly). The squeak doesn’t happen immediately upon moving but always happens within the first 20-30 feet of movement and then no more. If I put the truck in park, re-engage the automatic transmission and start moving, I cannot recreate the sound. However, if I turn off the engine altogether, restart the truck and begin moving, it happens again exactly as before. It happens every time the vehicle has been restarted, regardless of whether the engine is hot or cold. Once it’s happened, I can drive hundreds of miles and it won’t happen again until I turn off the engine and restart it. Further, I’ve determined recently that if I start the truck on a hill and let it roll while in neutral and without a foot on the brake, the squeak still happens. Therefore, it’s not dependent upon the transmission being in gear or the brakes being applied!
Any thoughts? HELP!!!
