What tool do I need to remove the battery cables from the battery?
Remove the negative terminal first. Attach the negative terminal last when reinstalling the battery. If the positive terminal is removed first and the wrench contacts any metal the battery will be shorted to ground and bad things will happen. I did it once and momentarily welded the end of the wrench to the fender.
Ed
