88 Ranger, 5 speed. When I take off from a stop or change gears everything is fine for a few seconds. Shortly after releasing the clutch pedal all the way the truck begins to lurch as if I’ve hit a patch or five of ice. This happens mostly after the engine is warm. Also happens in gears 1 thru 4. Haven’t tested 5th gear. Are the bands slipping? Tranny? Rear end? any ideas would be great… Thanks!
[b]That sounds like a slipping clutch.
Tester[/b]
Related topics
| Slipping tranny in 92 Ford Ranger | 5 | 711 | January 22, 2012 | |
| Jeep Transmission sliping | 1 | 381 | August 29, 2009 | |
| My manual makes a rattling sound | 115 | 18747 | February 18, 2023 | |
| Transmission slips - hiccups? 4th & 5th gear | 0 | 480 | September 26, 2009 | |
| Manual transmission slipping out of 5th gear | 8 | 64017 | July 24, 2007 |
