Put water in my steering pump
Needs to be flushed at least. Moisture in the pump will deteriorated the pump componants.
There had to be a reason you added water to anything. What was that ? If your vehicle is over heating then you need to find out why . How much water was added . If this vehicle is a recent purchase have someone show you how to check fluids and read the manual service schedule.
