Before replacing the BCM, make sure proper voltage is getting to all parts of the electrical system. Low voltage will cause strange symptoms, including what you are experiencing. The battery and alternator have to be in good shape, and all power leads and grounds must be clean and tight. Often overlooked are the two positive leads going into the power distribution center under the hood.
NYBo
4
| BCM Location? | 5 | 1444 | October 16, 2014 | |
| Dashboard dials (speedometer, etc) & air conditioning working intermittently | 4 | 2208 | July 23, 2020 | |
| Should I replace my ECMB? | 1 | 441 | February 20, 2014 | |
| Electrical | 1 | 200 | October 1, 2008 | |
| 2007 Toyota Camry died while driving but then came back to live after 10 mins as if nothing happens | 6 | 4298 | April 27, 2023 |
