Hi there! My car is only blowing air out of the floor vents and defrost. A/C and heat both work it just doesn’t come out of the dash. I was wondering if anyone knew what would cause that! Thank you!
The actuator (electric motor, gears and sensor in a box) that moves the door that directs that airflow is broken.
