Valve Spring Compressing
Okay just when I thought I had this thing going back together smoothly a new problem as emerged.
I put a new valve spring on because the other one busted.
Now when I am putting the push rod back in the spring is compressing down as the nut is being tightened. What is causing this issue?
Here is the image/
The camshaft lobe is in the up position for that valve.
Should I just keep tightening it down to the correct torque
If not what should I do to change it.
Torque it down and forget it.
Hard to say.
You don’t tell us what type of vehicle you’re working on.
Okay. Since that is the one I replaced the valve spring on and since it busted previously there wouldn’t be anything wrong causing it to be in the up position would there?
If not I can will glad to torque it down and forget. Thanks for your help guys!
Rotate the engine just a bit - 30 degrees or so, The rocker arm should move to relax the spring a bit as you do. Is this a Ford 3.8 V6?
Its the 3.0 Vulcan engine Ford Taurus
