What is a valve gasket cover,+what do it do?
And the reason you want a seal there is because oil splashes around under the valve cover. Without the seal, the oil will leak out.
Why do you ask?
I also need this for my car. Do they run high? 2003 Toyota Camry 4cld.
Are you asking about the gasket or the metal cover ? There is a difference . And do you plan to do this yourself?
No. They’re not expensive.
