The trooper has a 4 cyl. fuel inj. w/auto tranny. As of late, the tranny will shift intermittantly from overdrive down to 3rd then back up/ back down until I step on brake lightly then it stops shifting. This all happens when above 30 MPH and ONLY AFTER the first 15 minutes when started cold. The up/down shifting occurrs at low as well as high engine vacuum. When placing the tranny select in 3rd the violent up/down shifting stops but it runs at 3000 + RPM. The shifting while in overdrive is rather constant. I have checked and rechecked for vacuum line/hose leaks but found none. Can’t find anything on subject in repair manuals either. HELP!!!
Related topics
| 2000 Isuzu Trooper with the 40L30E automatic transmission. Have been having problems with the tranny not shifting from 3rd to Drive and spinning with no traction | 2 | 2984 | August 17, 2017 | |
| Tranny noise | 3 | 558 | March 10, 2010 | |
| Automatic Transmission Intermitently Fails to Shift into 3rd Gear | 3 | 1994 | May 12, 2010 | |
| 2001 Trooper problems | 0 | 264 | March 28, 2009 | |
| 98 isuzu trooper | 0 | 376 | June 22, 2009 |
