Unexplained light out
left headlight is out replaced new xenon bulb been told it may be the headlight assembly or ignitor light worked initally fluttered and then went out
Check to see if power is being supplied to the ballast (igniter). If 12V is available, then your ballast is faulty. You may just have a loose connection between the power and ballast or bulb and ballast.
thank you
