Trunk will not latch all the way
I have an '01 Focus Wagon. I’ve had this problem with the latching mechanism for a while, but it’s gotten worse as time progresses. The latch catches and closes the door. The trunk isn’t going to open, but it does not close fully. As a result, the door ajar light is always on my console. I used to fix it by manually closing the latch with by hand and then re-opening the latch. It closed almost every time after I did that. But now, even that is not working. Any way to fix this? Thanks.
Read this and see if it might apply to your vehicle.
It does, as it so happens. I’ll be calling them today. Thanks!
